I'm working on setting up an internet feed for my local UP line that runs through Jefferson City, Mo. I have an antenna temporarily mounted on my house as a test and have decided it will be worthwhile. I currently have a Radio Shack Pro-2026 that I plan to use, I know not the best scanner out there but it gets the job done.
Once in a while but not often I get some interference, one from a local hospital, and the other I have no idea what it is, just get a beeping tone once in a while, so I'm thinking perhaps something with better selectivity will help?
Either way I'd eventually like to get something else to use here at home for the feed as I do like to use the 2026 scanner in the car. Since I'm only going to be monitoring 3 channels speed isn't much of a problem. Is there a better option out there that isn't super expensive? I'm not opposed to buying used. Or maybe even and SDR? I have read a little about them but know very little.
I'll be monitoring 160.470 160.740 161.220 and the antenna will be a Slim-Jim made from copper pipe tuned to 160-164 MHz.
Thanks!
Thanks!
