The vehicle that I work out of (Appliance Repair) is a 2000 Subaru Outback. The car has a 6 CD changer that has never worked, it fits in a standard single DIN space.
The scanner that I normally use in this car is a Radio Shack Pro-2026 that sits either in the passenger seat or on the floor. I was noticing the other day that it would probably fit quite nicely where this non-working CD changer is, and I could cut an opening in the storage container below it for the sound from the speaker. However I like to have this particular scanner available for use in other locations as it has a discriminator tap, so I don't want to permanently mount it in the car, I'd like to buy another scanner. So I wanted some suggestions on perhaps a model that would better suit my use.
Must fit in a single DIN space which is 6.83" x 2" and can run on 12v DC input.
My main area of interest is the Railroad Band (I'm a Railfan), so if there is a model out there with better sensitivity/selectivity in the 160MHz range that would be a plus, but I do scan other bands from time to time.
Decent scanner speed is nice but I usually don't scan a lot of channels at one time so super fast scanning speed isn't needed.
If there is a model out there that has an audio output jack on the front that would be a nice plus, sometimes I like to run the audio through the car speakers, if it is on the rear that won't be very accessible, but that isn't a requirement.
I don't want to spend a lot of money on this, I'll likely be buying used, $100 or less would be ideal unless there is something out there that is significantly better and worth the extra money.
Or should I just look for any old scanner that will fit in this space?
Thanks!
Thanks!
