You didn't say what is your make/model of your scanner.
Is your scanner capable of recieving 26.965-27.405 in AM? If so yes. BUT.... that rubber resistor that came with your handheld (or small telescopic that came with your base/mobile unit) is hardly adaquate to recieve anything more than a few blocks away, if that. An outdoor antenna is essential. Even at that, most scanner antennae are not optimized for high hf spectrum. You'll be able to hear "chicken banders" up to a few miles away. At least you'll be able to hear further out than the stock antenna. You'll do best with an outdoor CB antenna. The downside to this is that when you want to monitor vhf/uhf/800MHz, you'll either have reduced sensitivity or an overloaded reciever when near towers and urban areas.
