mpcarlino
I apologize if this has been discussed elsewhere, but I really don't have the time to search the forums for it at the moment. Just putting it out there to see what I get.
I recently picked up a Radioshack 273-1766 6v 800mA wall wart for my BCD396T after the stock wall wart died on me. I noticed a significant increase in noise regardless of station. Even P25 transmissions have this background noise. It's not bad (but still noticeable) when using the internal speaker, but the noise when using headphones is much more severe; almost overcoming the voices in the transmissions. This was tried in two entirely different locations, and battery operation yielded the clean sound I expect. I know battery power is always cleaner, but this was almost to the point of inaudibility.
Has anyone used this particular unit for power on any scanner? I'm not sure if it's regulated (or if an unregulated unit would be so much noisier than a regulated unit), but the advertised "hash noise filter" isn't filtering anything at all. Any recommendations? Should I use some sort of inline noise filter, or consider another power supply?
Thanks!
Thanks!
