I have three scanners set up with antennas hanging with cheapo RG-58 coax.
1> BCT15 with 15' of coax hooked up to a RS800MHz antenna in the window.
2> Pro-97 also w/ 15' ft hooked up to a Nomad wire antenna for VHF (planes, trains, and some automobiles (CHP)) hanging outside off a roof eave.
3> When I'm not using it elsewhere, a BC246T hooked up to a Max Systems 800 antenna w/ 25' of coax in a window. (I know I need to shorten that length...but it still works better for trunking than anything else I have right now).
Both systems with their "800" antennas still pick up VHF, but the Radio Shack does better wide band while the Max does better on 800.
Anyway, while I know there is loss, the return of improvement of the various antennas being attached directly to the radios is still better. So I stay with it.
Like JM said..."That's all that matters"
