Please confirm if this is true. Config settings like hold, delay, and adding more and more
systems, groups to your scanner interferes with actual transmissions. I notice the more and more functions you give a scanner to perform the more it slows down and interferes with actual transmissions.
An example is with several systems being scanned and the config settings set with hold and delay times when an actual transmission is found the scanner is still trying to scan and sometime cuts the transmission short.
Has anyone else had to deal with this and how best to survive this.
Many Thanks
Many Thanks
