I have a keen interest in monitoring the Delta Air Lines system and figuring out their talkgroup usage. However I notice I'm clearly missing some conversations. I suspect this relates either to missing frequencies in the programming or LCN errors. The RR DB has a note that not all LCNs are confirmed. Has anyone had luck verifying the complete LCN structure for this system?
Well notwithstanding the fact that the Delta Air Lines LCN information in the database clearly isn't quite right (definitely missing some conversations entirely, but those that I receive sound terrific), I let Discovery Mode run on my SDS100 for a few hours. Just updated the database entry for the system to add talkgroups I was able to generally figure out usage for. You'll see a clear pattern.
Of course, now that we've determined 110## is Maintenance, 111## is Ramps, and 112## is gates (which, of course, is collectively the bulk of the traffic on the system), the real trick is to figure out usage for the more obscure Delta activities around the airport (11401, 11405, 11502, 11601, 11705, etc.). Of course it would also be good to figure out better specifics on how Maintenance uses the various 110## talkgroups assigned to them.
Overall I am relatively pleased with the SDS100. For me, it works much better on P25 simulcast systems than my 436 ever did, but not nearly as well as my Unication G5 or my Relm KNG radios. Then again, my G5 and KNGs don't have a Discovery Mode and all these other whiz-bang features (and don't do DMR and NXDN!). Nor does the SDS100 work as well for airband monitoring as my Yaesu FTA-250L. Unfortunately there's still not one radio to end all radios...
Dan
