MikeSD
- Joined
- Sep 28, 2010
- Messages
- 73
I have two barely used F21GM Radios. They are excellent GMRS radios and work great. I have tested both of these on all channels, with and without tones. They work great. There is one problem I'm experiencing on both radios. And both radios behave identically.
The problem: When I put a radio on ch16 (scan), the radio will scan, the light blink during scan, and when there is any signal, it stops, until the signal disappears and then continues scan. The problem is, most of the time all I hear is a continuous sound that sounds like unsquelched noise (I.e. The sound you get when you push moni, with no signal). Occasionally, there will be this brief noise, followed by silence. And once in a while it will work as I expect and I can hear the audio.
I have tested this scan using multiple other radios transmitting, and both of these F21GM behave identically as described above. This question is for those who have, have used, or know what might be causing the scan to work like this. What might be causing this behavior?
Any ideas? I suppose they could both be identically broken, but for now I'm thinking I just don't understand something about this mode. There are only about 2 sentences in the manual on scan.
