was looking at the yaesu ham radios and saw that they only tx up to 430. is their a ham radio that will tx in the gmrs bands without getting super expensive?
------------------------------------------------------------------------------------------------------------------------------------------------------------was looking at the yaesu ham radios and saw that they only tx up to 430. is their a ham radio that will tx in the gmrs bands without getting super expensive?
You can get a brand new VHF/UHF dual band Wouxun hand held that will do amateur and commercial frequencies for about $109. That's cheaper than most single band UHF amateur hand helds that are not type accepted for GMRS.
prcguy
W2NJS, Sorry but let's not tell others wrong infomation. Yes but the USEABLE part of the band for Voice Communications is from 442.000-445.000*Repeater inputs and outputs* and 445.000-447.000*Shared by aux and control links,repeaters and simplex*Local option**420.000 -426.00 is for ATV repeater or simplex with 421.25Mhz video carrier, control links and experimental* You cannot use voice and use the freqs of 420 to 421 as Voice Repeaters*Direct from THE ARRL REPEATER DIRECTORY 2009-2010.*Page 39 tells the use of the 420-450Mhz Band* Look it up!!!!! *THE ARRL IS RIGHT" This is the reason why Hams buy the ARRL Repeater Directory Book that comes out every year*
