Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > GMRS / FRS
GMRS / FRS - Discussions related to GMRS (General Mobile Radio Service) and FRS (Family Radio Service) communications
  #41 (permalink)
Old 12-29-2017, 5:55 PM
call_sign_null's Avatar
Originally Posted by KevinC View Post
I'll unstick it and leave it up to someone else to start e new updated thread.
Done!
https://forums.radioreference.com/gm...et-v2-0-a.html
I quickly made an updated version of Darth_vader's post and I will be making some additional edits. Everyone feel free to comment with suggestions and/or questions!
Matt Callahan | K7MFC | WRAA720
K7MFC.com | Arizona GMRS Repeater Club
var radioList = new List<Radio>();
  #42 (permalink)
Old 12-30-2017, 12:24 AM
RFI-EMI-GUY's Avatar
MY COMMENTS BELOW (BOLD)
================================ BANDWIDTH/DEVIATION ================================
FRS/GMRS - All channels
Bandwidth: 11 kHz
Deviation: 2.5 kHz
GMRS ONLY - 15-22*
Bandwidth: 20 kHz
Deviation: 5 kHz
*Note: GMRS may also be worked with 11 kHz bandwidth/2.5 kHz deviation, though most mainstream equipment (e.g. department-store HTs) is fixed for 20/5 operation.
NOT SURE WHAT IS MEANT BY "DEPARTMENT-STORE HTS" . DO YOU MEAN "PROFESSIONAL GRADE"? THIS IS A HOT TOPIC BECAUSE MIDLAND AND CHINESE ARE SLIPPING AWFUL NARROW BAND RADIOS INTO THE MARKETPLACE AND UNWARY CUSTOMERS ARE BUYING THEM.
MURS*
Bandwidth
1-3: 11 kHz
4-5: 20 kHz
Deviation
1-3: 2.5 kHz
4-5: 5 kHz
* Note: narrowband (11/2.5) transmissions are also allowed on MURS 4-5.
================================ THE FUTURE OF FRS AND GMRS ================================
It is speculated that licencing requirements on GMRS may be either greatly relaxed or completely eliminated in the coming years, and a slightly revised bandplan implemented. One oft-stated example has GMRS being restricted to 2 watts maximum ERP, simplex communications being allowed on the 467 MHz repeater input channels and repeater usage discontinued. The resulting service would be an "extended" 30-channel implementation of FRS and be regulated as such.
MUST WE SPECULATE ON SUCH AN AWFUL OUTCOME? GET LICENSED FOLKS, HELP GMRS STAY RELEVANT AS A HIGH PERFORMANCE SERVICE.
"Have Spectrum Analyzer, - Will travel" "Going Green"
  #43 (permalink)
Old 12-30-2017, 3:36 AM
W9BU's Avatar
Lead Wiki Manager
Originally Posted by RFI-EMI-GUY View Post
Bandwidth: 20 kHz
Deviation: 5 kHz
Carson's Rule states that the occupied band width is equal to two times the deviation plus the highest modulation frequency. As a formula:
BW = 2 ( f(d) + f(m) )
The highest modulation frequency for two-way communications is generally accepted to be 3 kHz.
So, the bandwidth for 5 kHz deviation would be 2 ( 5 + 3 ) = 16 kHz. For 2.5 kHz deviation, it's 2 ( 2.5 + 3 ) = 11 kHz.
Lead Wiki Manager and Forum Moderator.
"The whole world's living in a digital dream. It's not really there, it's all on the screen." -- WB6ACU
  #44 (permalink)
Old 12-30-2017, 1:40 PM
I am not the one who originally posted this my comments are the ones in BOLD. That said, here goes.
The FCC has a different way of specifying the BW, (They use a spectral mask). The BW they state, is. 20 KHz for GMRS and FRS should be 12.5 KHz. This is to fit into a mask. Carsons Rule perhaps does not account for noise plus distortion products and thus a splatter filter sometimes is required. Plus when trying to cut off any voice energy, especially after being pre-emphasized, at 3,000 Hz no low pass filter is perfect. So Carson's Rule, in my opinion is good theory, that falls a bit short of practice,
Confusing all of this is the fact that radios will be certified with 20K0F3E and 16K0F3E emissions in GMRS Part 95 (and legacy Part 90).
Why 20 KHz BW inside a 25 KHz channel spacing? Additional protection for frequency error of the transmitter and receiver plus uncertainties in receiver filter BW.
95.1773 GMRS authorized bandwidths.
Each GMRS transmitter type must be
designed such that the occupied
bandwidth does not exceed the
authorized bandwidth for the channels
used. Operation of GMRS stations must
also be in compliance with these
requirements.
(a) Main channels. The authorized
bandwidth is 20 kHz for GMRS
transmitters operating on any of the 462
MHz main channels (see 95.1763(a)) or
any of the 467 MHz main channels (see
95.1763(c)).
(b) Interstitial channels. The
authorized bandwidth is 20 kHz for
GMRS transmitters operating on any of
the 462 MHz interstitial channels (see
95.1763(b)) and is 12.5 kHz for GMRS
transmitters operating on any of the 467
95.1763(d)).
(c) Digital data transmissions. Digital
data transmissions are limited to the 462
MHz main channels and interstitial
channels in the 462 MHz and 467 MHz
bands.
95.573 FRS authorized bandwidth.
Each FRS transmitter type must be
bandwidth does not exceed 12.5 kHz.
Tags
frs, gmrs, murs
