Are there any GMRS mobile antenna's available?
kc0bus
Hello,
I'm a beginner in the GMRS world. Anyone know if there are 1/4-wave or 5/8-wave antenna's available for GMRS intended for mobile application (especially magnetic mount use)?
Thank you
FFPM571
Nashvillle
You can use any commerical two way antenna for the 460 mhz band nothing special about GMRS antennas
Hello,
Thank you
Any antenna that will resonate at 462 - 467MHz will work just fine.
I ran Larsen NMO-Q quarter wave antennas for many years when I was on GMRS. You can purchase 5/8th's wave UHF antennas, also.
If you -must- use a magnetic mount, just get an NMO Magnetic Mount base and purchase the antenna(s) you want to use.
S1deband1t
Glenside, Pa.
You actually don't need to go with a 1/4 wave since at UHF frequencies the waves are already shorter. I am not positive, but I am somewhat confident that you may be able to go with a full wave antenna (especially if you are looking into a mag mount).
I am currently looking at the Tram 1170 which is a high gain antenna with +4.5dB gain (about 3 times the range as a normal gain antenna).
