Radio Cases
backseat_nick
I use my radios for film so I'm looking for a light weight hard or semi rigid case that can hold 6-20 walkies chargers and batteries.
Id like to transport the walkies with standard length antennas attached.
Price is an option and optimally I could buy the item on amazon.
Thanks in advance for your advice.
Sent from my MotoG3 using Tapatalk
PACNWDude
Pelican makes some great cases that hold up to hard use. Pick and pluck foam also allows you to make them a bit customized for whatever you place in them.
Several companies I have worked for have used these for transporting large amounts of radios and accessories to the field.
Newer Stormcase cases are not quite as durable though.
Here's what I use at work.
This is a kit of 6 Kenwood NX-410 800MHz radios with a 6 slot charger. We rent this out occasionally and needed a way for our customers to have everything in one place with dedicated slots for each item so they'd be able to see if something was missing. I ~think~ it's a Pelican 1650 case. Not "cheap", but it'll be the last one I have to buy.
Antennas are removed and placed in a hole next to the radios. Doing this without removing the antennas would have required a much larger case. Haven't had any issues with customers not installing the antennas. I've got a single sheet laminated card that goes in the case with instructions on set up and use.
