I just bought a full-sized GE MASTR II repeater for $199.99. If nothing else, the two power supplies and two 100 watt continuous duty amplifiers are worth far more than the entire unit, so I don't think I got a bad deal...
...especially if I part out the 2nd amp and power supply. I plan to keep only one amp and set it for 50 watts continuous duty.
I already have a Decibel DB4076W-A copper duplexer that should work well with this.
Now I just need to make arrangements for a friend to drive me up to Milwaukee in his pickup truck to haul this H U G E monster back down to Hammond, Indiana.This is the high power version of the GE MASTR II repeater, it has the typical rack mountable MASTR II with two additional RF power amplifiers and power supplies. The Combination Number is VCS5TAD88B. The repeater is currently on 454.650 R / 459.650 T, and was used for a short time as a GMRS repeater. The RF output was recently measured at 160 watts continuous output.This is a large floor mounted cabinet that measures 69" H, 23" W, 21" D, weight is 400 lbs. Operates from 120 VAC single phase power.
