Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > GMRS / FRS
GMRS / FRS - Discussions related to GMRS (General Mobile Radio Service) and FRS (Family Radio Service) communications
Old 05-15-2018, 11:27 AM
Default GMRS only
Since I'm strictly a noob to GMRS,I have been looking around trying to find the "perfect" transceiver to buy.Most of the radios I see are of the FRS/GMRS variety. Are there any radios that are strictly GMRS only? I think I am wanting a higher power radio.
Old 05-15-2018, 12:11 PM
You could always get a programmable radio and program only GMRS frequencies and leave out any FRS channels from selection.
Old 05-15-2018, 12:19 PM
Do you want a hand held or mobile...
If you want higher power, MIdland makes a 40 Watt GMRS mobile... https://midlandusa.com/product/mxt40...e-2-way-radio/
Old 05-15-2018, 12:44 PM
If you're interested in a good quality radio and want to stay away from the blister-pack kids toys, you may want to consider a Kenwood TK-390 handheld or a TK 880 or TK8180 mobile radio. All are widely available on the used market, are fairly inexpensive and reliable. You will need a programming cable and software but those are easy to come by as well. Additionally they're certified for Part 95 use so you'll be on the "up and up" if that's to your liking. They're available in different band splits (frequency ranges) so you'll need to make sure you're purchasing one that encompasses the GMRS band.
Old 05-15-2018, 12:58 PM
mmckenna's Avatar
Been a while since I've been active on GMRS, but back when I was, I used Icom commercial radios.
Most serious GMRS users do.
A commercial radio will outperform the consumer grade radios as well as give you a lot more options.
The trick is finding a commercial radio that has the necessary FCC Part 95 certifications. The Kenwood's mentioned above do, as do some of the older Icom's.
Plus, adding a good external antenna on a mobile radio will greatly improve performance, either as a mobile or a base.
Old 05-15-2018, 1:21 PM
Thanks guys. I should have mentioned that I want a hand held capable of getting on repeaters. With as many ch power as possible. I think I want all this,maybe someone will steer me in another direction.
Old 05-15-2018, 2:02 PM
Default GMRS HT
Take a look at this review and radio. BTech GMRS V1 - Miklor
Miklor is an established and trusted site. These are not Motorola quality but appear to be better than the entry level Baofengs and should neet your needs.
Old 05-15-2018, 2:20 PM
mmckenna's Avatar
A used Kenwood TK-3180 will do a lot, and can be had reasonably inexpensive.
Don't fall for the new guy mistake of looking for the highest power output you can. RF power isn't as important as your antenna. Adding more power will drain batteries faster and not get you as much additional range as you might think. It's all about good antennas and sensitive receivers, something you'll never get from the bubble pack consumer radios.
The Kenwood programming software is easy to use. Accessories are plentiful and inexpensive since it shares them with a lot of other Kenwood models.
I've got one I use as a shop radio, and for a basic analog UHF radio, I'm pretty happy with it.
Old 05-15-2018, 3:01 PM
For example:
My GMRS repeater is located on a rather prominent ridge (not a mountaintop), and I get an honest 12-14 mile full quieting range with 25 watt commercial grade mobiles and roof mounted antennas. I can still hear with the portables at 10-12 miles out, but I can't key the repeater from inside my car w/ a portable at that range.
Used Motorola M1225 mobiles are a dime a dozen, the software is accessible & easy to figure out, and they're part 95 type accepted. Kenwoods aren't bad either, and the software is just as easy to find.
Old 05-15-2018, 4:18 PM
Since you want a handheld, commercial grade ones are pretty much limited to 4 watts output, which is still twice the 2 watts or so that the bubble-pack toy radios give you.
With a real 4 watt commercial grade radio, you get a detachable antenna. Which means that, under the rules, you cannot use FRS channels 8-14. (These channels are also limited by the rules to 0.5 watts ERP.)
Personally, I would program in channels 1-7 for short range simplex use, as well as channels 15-22, with both simplex and repeater capability. A GMRS license allows you to use all of those channels, so put them all in.
John
WPXJ598
Peoria, AZ
Old 05-15-2018, 4:49 PM
John
WPXJ598
Peoria, AZ
So which radio would you recommend?
Old 05-15-2018, 4:52 PM
I found one of those for a decent price,but looks complicated to use as I don't know squat about these radios.
Old 05-15-2018, 4:55 PM
TK-390 also is Part 95. Cheaper than the TK-3180, but older. Plentiful for chargers, batteries and audio accessories as well to be had.
I just bought 6 for my in laws.
Interoperatablity is not a technology, it is an attitude!!!
Old 05-15-2018, 5:25 PM
The TK3180 is a nice radio. While it is capable of trunking, you don't need to program any trunking capabilities. As I recall, when you first open the programming software to write a new codeplug, you can choose the mode of operation. Chose the non-trunking option and it becomes pretty simple. If you're comfortable programming radios with other software I think you'll find it fairly intuitive. Although it has many additional features, you don't need to make use of them.
Old 05-15-2018, 5:32 PM
I personally do not have a recommendation. I have an old Icom U16 handheld, but it needs a new battery pack I believe. Secondly, 3 of the 4 main GMRS repeaters here in the Phoenix metro area are narrowband, and the U16 is only wideband. And lastly, my family isn't really all that interested in using radios, so I'm the only one who has a GMRS capable radio. I monitor once in awhile via my scanners, but otherwise I'm inactive on the GMRS. (Yes, I just renewed my license anyway.)
John
WPXJ598
Peoria, AZ
Old 05-15-2018, 5:40 PM
Yes you might as well keep it.I foolishly let my ham tech license lapse.
Old 05-15-2018, 5:41 PM
GMRS trunks?
Old 05-15-2018, 5:47 PM
GMRS trunks?
No, he was saying that the radio is capable of trunking. Trunking is not (normally*) used in the GMRS.
* I wouldn't be surprised to find a trunked system using GMRS channels, since some users are also using digital modes that are not permissible in the GMRS.
John
WPXJ598
Peoria, AZ
Old 05-15-2018, 6:15 PM
John
WPXJ598
Peoria, AZ
Ok thanks. (See how dumb a noobs questions can be )
Old 05-15-2018, 6:29 PM
mmckenna's Avatar
Nah, these are good questions, don't sell yourself short.
The consumer grade radios are designed to be simple to operate, and thus have simplified interfaces.
The commercial radios are designed to be programmed by a radio shop or radio tech to fill the needs of the end user, so they appear to be very complicated.
The nice thing is, you can set them up the way YOU want. It takes some time and experience to be good at it, but it's a good thing.
I had a couple of Icom's when I was active on GMRS. I had my own set up to allow a lot of complex functions. The other radios were set up to be more "fool proof". Most of the functions were disabled and just the "need to have" stuff was available to the user, on/off-volume, channel change, push to talk. That is a great way to set up a radio for kids or non-technical types, less trouble they can get into, less mistakes can be made.
As you get more experience, you can open up more of the functions.
But as others said, these radios will have functions you'll never use.
