Opinions Comet CA-712EFC 460-470MHz
cmdrwill
So Cali
If you saw the insides, cheep steel wire with a piss poor copper plating, you would get a better antenna.. CCA that is how they save on making these junk antennas.
SpugEddy
Camden County South Jersey
WOW. OK!
What is a good antenna that is in the same price range?
I am well aware of the old saying "a great system is often
made up of 10% radio and 90% antenna" but I really don't
have a large budget. I think mmckenna often suggests Larsen
and I forgot the other. Any suggestions?
SpugEddy
The Larsens and the laird antennas that are in
my budget are either unity gain or nothing above
3db. Looking for something omni directional with
at least 6db
cmdrwill
So Cali
at least 6db
The Comet is no where near 6 dbd gain. They use a different dbi to rate their antennas because it IS a bigger number. Not apples to apples.
Commercial UHF antenna with a REAL 6 DB gain would be 98 to 100 inches tall.
Also check Comprod, Comtelco and Telewave.
kayn1n32008
ØÆSØ
Sector 001
at least 6db
Honestly, you will see little difference between a 3dB gain antenna and a 6dB gain antenna.
