You're supposed to be able to hook up the scanner, and Windows takes care of configuring the device.
/QUOTE]
if i had a dollar for every device that was Supposed to be plug n play with windows...id have several psr 800s in my stable..
the disk that has the ezsan software...also has the drivers/driver info..
read the INF file...all devices have drivers man!...
try instaling/reinstalling the software...
; Microchip Composite Device MSD+CDC
; This driver is required only by the CDC part of a composite device.
; The MSD part does not require any driver.
; Copyright (c) 2000 Microsoft Corporation
; Copyright (C) 2007 Microchip Technology Inc.
; Copyright (c) 2010 General Research of Electronics
[Version]
Signature="$Windows NT$"
Class=Ports
ClassGuid={4D36E978-E325-11CE-BFC1-08002BE10318}
Provider=%MFGNAME%
LayoutFile=layout.inf
CatalogFile=%MFGFILENAME%.cat
DriverVer=11/15/2007,5.1.2600.0
[Manufacturer]
%MFGNAME%=DeviceList, NTamd64
[DestinationDirs]
DefaultDestDir=12
; Windows 2000/XP/Vista-32bit Sections
[DriverInstall.nt]
include=mdmcpq.inf
CopyFiles=DriverCopyFiles.nt
AddReg=DriverInstall.nt.AddReg
[DriverCopyFiles.nt]
usbser.sys,,,0x20
[DriverInstall.nt.AddReg]
HKR,,DevLoader,,*ntkern
HKR,,NTMPDriver,,%DRIVERFILENAME%.sys
HKR,,EnumPropPages32,,"MsPorts.dll,SerialPortPropPageProvider"
[DriverInstall.nt.Services]
AddService=usbser, 0x00000002, DriverService.nt
[DriverService.nt]
DisplayName=%SERVICE%
ServiceType=1
StartType=3
ErrorControl=1
ServiceBinary=%12%\%DRIVERFILENAME%.sys
; Vista-64bit Sections
[DriverInstall.NTamd64]
include=mdmcpq.inf
CopyFiles=DriverCopyFiles.NTamd64
AddReg=DriverInstall.NTamd64.AddReg
[DriverCopyFiles.NTamd64]
%DRIVERFILENAME%.sys,,,0x20
[DriverInstall.NTamd64.AddReg]
[DriverInstall.NTamd64.Services]
AddService=usbser, 0x00000002, DriverService.NTamd64
[DriverService.NTamd64]
ServiceType=1
StartType=3
ErrorControl=1
; Vendor and Product ID Definitions
; When developing your USB device, the VID and PID used in the PC side
; application program and the firmware on the microcontroller must match.
; Modify the below line to use your VID and PID. Use the format as shown below.
; Note: One INF file can be used for multiple devices with different VID and PIDs.
; For each supported device, append ",USB\VID_xxxx&PID_yyyy" to the end of the line.
[SourceDisksFiles]
[SourceDisksNames]
[DeviceList]
%DESCRIPTION%=DriverInstall, USB\VID_0C97&PID_0008&MI_01
[DeviceList.NTamd64]
; String Definitions
;Modify these strings to customize your device
[Strings]
MFGFILENAME="mchpcdc"
DRIVERFILENAME ="usbser"
MFGNAME="GRECOM"
INSTDISK="GRECOM Installation Disc"
DESCRIPTION="GRECOM PSR-800 Serial Device
SERVICE="USB RS-232 Emulation Driver"
