I do not have any attenuation turned on.It is deaf as a brick on the digital side of the radio.I am also a ham operator so I am very familiar with complicated radios.I have been using scanners for 20+ years.I keep thinking I might of missed something in the set up but the digital stuff was working at one time.
I felt the same exact way 2 years ago, when I purchased a 996XT. The best advice I could give you would be to find someone w/ a ready-made file for MN that you can upload to your scanner. You do have a cable and program to upload a file to your scanner, don't you? Once you see how the "channels/ sites" are used or programmed in you will figure it out.
Check out older threads in the MN forum (past year for sure) and I am sure you will come across one someone has posted. I have even seen people make "custom" files for fellow hobbyist's.
Here is what I am talking about. It is in the thread: Anyone want to help a noobie?
TRY THIS SCANLIST 6
