  #21 (permalink)
Old 02-11-2017, 12:11 PM
n8jsw's Avatar
If you did the update on the psr800 for DMR you have to use the ezscan 1080 to program it and update it
N8JSW
Icom Ic-2350H, Uniden BCD396XT,Uniden 996P2
  #22 (permalink)
Old 02-11-2017, 12:21 PM
Originally Posted by baboon53315 View Post
Another question.I did the whistler mod .I tried to do the DSP update,my computer says the scanner not connected.When I go into ezscan,do I go into the psr ezscan or the ws1080 ezscan.Also to do my sd card update for my programs,do I still use the psr or ws1080.Thanks
You need to install the ws1080 driver. get it from whistler for free, You use ezscan for the ws1080 you also get that from whistler for free.
  #23 (permalink)
Old 02-11-2017, 12:22 PM
there is no dmr update for that scanner. its for a newer scanner. can listen to dmr by turning on the discriminator tap (goto settings then IF output, change it to HP, connect headphone jack to line in on computer and run dsd program. its not trunked mode but at least you can hear it
Solgar put a warning on your zinc supplements - maybe cause panic attacks
https://www.curezone.org/forums/fm.asp?i=2403492
  #24 (permalink)
Old 02-11-2017, 12:23 PM
n8jsw's Avatar
Well I have a psr and have dmr on it so it is capable of it
N8JSW
  #25 (permalink)
Old 02-11-2017, 12:32 PM
buddrousa's Avatar
PRO-18 also hears P25 Phase 1, Phase 2 and DMR.
Support your local FIRE & EMS. PRO197-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP BCD536HPx3 BCT346 BCD996P2 x3 BCT15x2 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 Tk280 TK2180 MD380x4 NX5300 NX5200 Buddy
  #26 (permalink)
Old 02-11-2017, 12:36 PM
DMR is achieved by using the unofficial upgrade to the firmware. Works with the Pro-668, psr-800 and pro-18
  #27 (permalink)
Old 02-11-2017, 7:31 PM
baboon53315's Avatar
Hello.I have gone to Whistlers website.Went to downloads and to ws1080 pc driver.Clicked onto it and there is no download to click.Very frustrating.The scanner powers up saying WHISTLER,works on my old scanlist.
  #28 (permalink)
Old 02-11-2017, 7:38 PM
Hello,
You need to "buy" it and checkout. It has a cost of 0.00 so no money is required.
73 Eric
  #29 (permalink)
Old 02-11-2017, 7:40 PM
https://whistlergroup.com/products/w...1088-pc-driver
  #30 (permalink)
Old 02-11-2017, 7:46 PM
Hello.I did the "buy" and checkout.Do I have to fill out the personal info to go further?Thanks
  #31 (permalink)
Old 02-11-2017, 8:06 PM
yes
  #32 (permalink)
Old 02-12-2017, 12:42 PM
car car is offline
I would appreciate someone sending me the FW 3.8 file....Thanks
  #33 (permalink)
Old 02-12-2017, 12:51 PM
car car is offline
Thank You simmsrep
  #34 (permalink)
Old 02-12-2017, 12:54 PM
simmsrep's Avatar
Your welcome. Enjoy!
Sent from my SM-G900V using Tapatalk
  #35 (permalink)
Old 02-12-2017, 2:23 PM
Thanks to everyone for all the help and information.Going to try this again.LOL
  #36 (permalink)
Old 02-26-2017, 12:46 PM
Hi guys.Downloaded the driver.I still can't update the DSP and can't update my SD card.My computer is still telling me the scanner is not connected.The only way I can update the SD card is through my card reader.Does the DSP need to be updated in order for the DMR systems to work?Everything else works fine,but still not hearing anything on DMR.
  #37 (permalink)
Old 02-26-2017, 2:39 PM
I'm sorta new at this, but I'll give it a shot. Use the GREFwToolWin0.2.0.3 to update the firmware. Use the WHISTLER EZScan software (NOT the PSR-800 EZScan) to check/upgrade the DSP. I think that ver 3.0 ithe latest. Also, you will need the WS-1080 .inf drivers for the computer to recognize the scanner once the FW is updated.
With the latest version of GREFw tool, you can download the latest FW from within the tool (I think 4.5 is the latest). I hope this helps.
73
  #38 (permalink)
Old 03-02-2017, 5:51 AM
The upgrade is simple as use the FWTool put version 4.5 CPU in it. Upgrade the DSP to 3.0 and run the WS1080 ez scan. Download your old scanner files into the 1080 ez scan and your set. Done both my 800's in under 5 minutes a unit.
Pleased to say the digital decode is better and the DMR decode is a bonus. My TRX-1 is still the top dog though.
www.goulburnscan.com
Your source of scanning in the Southern Tablelands NSW.
  #39 (permalink)
Old 03-03-2017, 4:57 AM
I have a question, currently my PSR 800 is running the 3.8 whistler firmware and I want to put the 4.5 in it, do I select the WS1080 in scanner type in the GREF tool since it has the 3.8 in it. Just wanting to make sure so I don't screw up my radio
  #40 (permalink)
Old 03-03-2017, 6:03 AM
Hello,
No, the scanner type always stays the actual hardware. It is the firmware type that is changed and stays WS1080 to put 4.5 on the scanner.
73 Eric
