Old 02-04-2018, 11:44 AM
bigcam406's Avatar
Default How to clean buttons on PSR500
Hey guys. Have a well used 500 and was wondering how to get the yellow buttons clear again or is it basically a sign of age? Thanks
Uniden's BC898T 125AT 95XLT GRE 310 410 500 600
Old 02-04-2018, 12:06 PM
Ronaldski's Avatar
MI DB Admin
If they turned tan or as you say a yellow color, then someone in the house is very likely a smoker?
Seen this many times and its always been where someone smokes. Side note, maybe the buttons turning brown is trying to teach a lesson?
I saw one that turned a dark brown and they stated they actually had a house fire!
Cleaning is possible I'm sure, but presumably would it also remove the numbers, lettering, etc. from the buttons?
Old 02-04-2018, 7:24 PM
scanlist's Avatar
It is a sign of age. I have a PRO-106 that is approaching 10 years of use in a non smoking environment and the keypad is turning to a yellowish brown shade.
As long as the buttons work properly when pressed you are good.
Old 02-04-2018, 8:31 PM
Nasby's Avatar
Thumbs up
It's nicotine (imagine what that scanner owner's lungs look like).
Try a Q-Tip dipped in bleach.
Boycott the NFL.
Old 02-04-2018, 8:34 PM
Old toothbrush, spray with Windex and shake off excess, then scrub lightly and dry with paper towels.
Old 02-04-2018, 11:51 PM
bigcam406's Avatar
thanks for the replies. it has been in a non smoking home for 6 years.
Old 02-05-2018, 8:37 AM
Nasby's Avatar
It should be really easy to clean then since its not nicotine.
I've had a PSR500 for nearly 10 years of heavy use and found that just a dab of bleach or cleaner (Windex, etc) on a Q-Tip should do the trick.
Boycott the NFL.
Old 02-05-2018, 1:33 PM
wa8pyr's Avatar
Technischer Guru
Alcohol prep pads such as those used in the doctor's office before giving a shot work great for cleaning off fingertip grime. I use them for cleaning computer keyboards also.
Tom Swisher, WA8PYR
Lead Database Administrator
PSR500/Pro197/Pro2035+OS535/BCD436HP/TRX-1
