SPECIAL FEATURES OF THE NEW GRE PSR-500
1. AN LED ON TOP THAT CAN BE 8 DIFFERENT
COLORS, EACH COLOR TIED TO AN OBJECT
(TALKGROUP OR FREQUENCY) SO FOR EXAMPLE
POLICE CAN LIGHT UP BLUE AND FIRE, RED
THIS LIGHT CAN BE STEADY OR BLINKING
ALSO, ONE CAN HAVE UNLIMITED VARIATIONS
OF COLOR USING ANY MIX OR RED, BLUE, & GREEN
2. 700 MHZ APCO 25 - 700 MHZ I CALL CAPABILITY
3. MOTOROLA SMARTZONE - SCANNER CAN LOOK
FOR THE SITE WITH THE BEST RECEIVED CC
DECODE RATE
4. A "HOME SET" OPTION LETS YOU CREATE A
SCAN LIST/GROUP CUSTOMIZED TO YOUR
FAVORITES - ONE BUTTON OPERATION
5. A "FIND OPTION" THAT LETS YOU TYPE A
PARTIAL OR FULL ALPHA-NUMERIC AND IT
WILL SEARCH ALL THE NUMBER AND TEXT
FIELDS IN EVERY OBJECT AND LET YOU CHOOSE
TO EITHER MONITOR(MAN) OR PRESS NEXT TO
KEEP FINDING
6. HAS UP DOWN ARROW KEYS TO SCROLL WITHIN
A SCAN LIST, AND LEFT RIGHT ARROW KEYS TO
CHANGE SCAN LISTS
7. NO FREQUENCY LIMITATION ON TRUNKING
8. MORE EFFICIENT USE OF TALKGROUPS - YOU
CAN USE THE SAME TALKGROUPS IN MULTIPLE
SCAN LISTS, SO AS NOT TO HAVE TO ENTER THE
TALKGROUP MORE THAN ONCE
9. ONE CAN PAUSE ON A TALKGROUP, AND LEAVE
IT FOR DAYS. THE SYSTEM OBJECT WILL
HANDLE ALL OF THE CONTROL CHANNEL
TRACKING FINE SO LONG AS THE RADIO IS
POWERED UP, AND SO LONG AS YOU HAVE
ALL POSSIBLE CONTROL CHANNELS IN MEMORY
10. COMPLETE COMPUTER CONTROL, VERSUS
JUST THE UPLOAD AND DOWNLOAD ABILITY
OF PREVIOUS GRE MADE RADIO SHACK RADIOS
11. WHATEVER THE LAST OBJECT YOU SCANNED
OR FOUND IS THE OBJECT THAT COMES UP
WHEN YOU PRESS MAN
12. ALL MENU ITEMS HAVE A "DEFAULT OPTION"
KEY SO IF YOU ACCIDENTALLY SCREW SOME-
THING UP, YOU CAN RESET JUST THAT SPECIFIC
ITEM BACK TO ITS DEFAULT VALUE
13. 21 VIRTUAL SCANNER (V SCANNERS)
14. HAS SPECTRUM SWEEPER (LIKE CLOSE CALL) WITH LOCKOUT
15. SKYWARN FEATURE
16. 5 WAY NAVIGATION KEY
17. 3 USER FRIENDLY(MENU SELECT) KEYS"
Brian
Campbell, CA
List Owner:
SantaClaraCountyScanning@yahoogroups.com
