Hi guys,
I've currently got a BC-245XLT and am thinking of upgrading. My question is,
how does one select a particular scan object via the keypad? The reason I
ask is that I'd like to also use the scanner to listen to communications
while I go to the races at Texas Motor Speedway. With the 245XLT I simply
put the car's frequency under the channel that corresponds to the car
number, e.g., car 16's freq in channel 16. That way I can quickly access any
particular car's communication. It seems that the memory in the PSR-500 is
dynamic so to speak so I'm not sure how I could do the same "car selection"
with it. Is it even possible?
Thanks.
R. P.
Thanks.
R. P.
