OCFA and other partner agencies have adopted a radio frequency program called "SOLAR" for use during mutual threat brush fires. SOLAR stands for San Bernardino, Riverside, Orange, and Los Angeles Counties. (Although its my understanding that the Fallbrook/N. San Diego County agencies are also using it). The "OC Access" channel is often used as a command channel on its own, however it may also be linked with other frequencies such as CALFIRE Command 2 to allow better cross-agency communications. Activation of the link is done by OCFA ECC/OCC and may be coupled for any frequency in the plan, however its often the command channel that is linked. When not in use for brush fires you may hear sigalert broadcasts and other non-fire traffic.
All fire agencies who participate in mutual threat such as Brea, Anaheim, Corona, etc. also participate in the program, not just the large agencies. OCFA has decided to use the program for all brush fires, no matter where in the county, to better prepare and practice their staff to use the VHF system. While dispatch occurs for OCFA on 800 Mhz., the plan is implemented immediately from that point forward for incident communications. Here is the frequency lineup for the plan:
1 CDF C1 151.3550 0.0 159.3000 MPL CDF COMMAND 1
2 CDF C2 151.2650 0.0 159.3300 MPL CDF COMMAND 2
3 CDF C3 151.3400 0.0 159.3450 MPL CDF COMMAND 3
4 CNF 168.7500 0.0 171.4250 MPL USFS Cleveland NF
5 OC ACCESS 151.0850 (4) 136.5 159.0000 (4) 136.5 Orange County Access OCC
6 WHITE 2 154.2650 0.0 154.2650 0.0 White Fire 2 aka VFIRE 22
7 WHITE 3 154.2950 0.0 154.2950 0.0 White Fire 3 aka VFIRE 23
8 VTAC 11 151.1375 0.0 151.1375 (6) 156.7 VHF Interop VTAC 11
9 VTAC 12 154.4525 0.0 154.4525 (6) 156.7 VHF Interop VTAC 12
10 NIFC T2 168.2000 0.0 168.2000 0.0 NIFC TAC 2
11 FSR5 T5 167.1125 0.0 167.1125 0.0 USFS RGN 5 Tac 5
12 CDF T15 159.2700 0.0 159.2700 0.0 CDF TAC 15
13 CDF A/G 151.2200 0.0 151.2200 0.0 CDF Air To Ground Net
14 FS A/G 170.0000 0.0 170.0000 0.0 USFS Air To Ground Net
15 LAC T19 154.4000 0.0 154.4000 (14) 151.4 LAC Tac. 19 / Air to Ground
16 GUARD 168.6250 0.0 168.6250 (1) 110.9 Air Guard
