San Bernardino County P25 system
avdrummerboy
Mohave County, AZ
Hey all, from a source, I have obtained the CC frequencies from the county radios. I will list them in their entirety. The ones with names after them are the ones that have been found on the RR website for the system. The rest I assume are for other sites not yet identified or for later use. Adding here for us to add in and monitor. For whatever reason Rodman, Ontario PD, County General Services, homestead, and Bertha aren't in this radio, maybe only certain radios have those CC's in them.
858.3625
857.8125
769.59375 HD Sumulcast
771.60625-E Val Simulcast
771.75625- Mtn. Simulcast
772.00625-Mtn. Simulcast
772.01875- W Val Simulcast/ CSU Palm Des
772.25625- W Val Simulcast
772.26875- Flash II/ CSU Palm Des
772.58125- E Val Simulcast
772.59375
772.83125
852.1875- W Central Simulcast
852.4000
852.575
852.6000
852.6375-W Central Simulcast
852.8500
852.8625-E Central Simulcast
852.9500
853.0750
853.1250
853.1375- E Central Val Simulcast
853.1750
853.3500
853.4750
853.6000
853.6250
853.6375-E Central Val Simulcast
853.6500
853.6750
853.6875-Onyx
853.8375 E Central Val Simulcast
853.8500
853.8625
853.8750
853.9000
854.2875
858.2875
859.1625
859.2375
859.5375
860.0875
860.1375
860.3125-HD Simulcast
860.5875-HD Simulcast
860.6125
860.6625-Paxton
860.8375-Onyx
861.1375-Paxton
868.6500-HDDC
868.9000-HDDC
kearthfan101
Thank you! Were you by chance able to get the full site list also (site alias)?
avdrummerboy
Mohave County, AZ
Unfortunately, no, it's kinda weird how it's set up, there are no site aliases just a master list of control channels in the codeplug, and apparently not a full one seeing as how many are missing from the known list already compiled.
allend
Long Beach, CA
Keep in mind that all 16K radios will be re-programmed to clear out the old analog programming and the zones and there will be a finalized P25 Digital Codeplug countywide being pushed in the near future.
zumachris
Los Angeles County, CA
Anyone have information of 8-LAW-1 et al (sheriff) in San Bernardino County? They don't seem to be on the old system with fire any longer. Are they moving to a P25 system like described here?
allend
Long Beach, CA
All of Law Enforcement for SBDCO has moved to a new P25 system and is encrypted and silent. So you are out of luck
avdrummerboy
Mohave County, AZ
In listening out where I work in Joshua Tree, been hearing a few TG's popping up. Figured out that 3775 is County animal control, Station Oscar. I'll submit soon as long as I don't hear anything else under that ID.
Another ID that is popping up is 2529, still haven't caught any designators yet so unsure what the use is. But I'm still listening.
Edit- of course as soon as I post this I hear call signs on it "108 to 110" which used to be the designators for the local, I believe Yucca Valley, animal control department.
jrholm
Big Bear
was scanning on the way home and Ontario PD was encrypted. Didnt get a chance to see if they were still on System 9 too
breed909
San bernardino CA
So i have been hearing a lot of radio transmissions on the P25 system the last couple days did they move SBCO fire to the P25 system I have been getting a lot of San Brnardino city fire Colton Redlands and Rialto High desert Yucca Valley just been a hole lot of different transmissions hear are some of the talk group ID's
Not sure is this will help anyone but hear are some of the ID's that i have seen my BCD436HP doing id scan on the P25 System
3375 <----- Think this is animal control not sure what city
2989 <----- Scanner just stops on this one (no talk)
2579 <----- Scanner just stops on this one (no talk )
1299 <----- Scanner just stops on this one (no talk )
2563 <----- Came up with a ID station 11 Coroner
3489 <----- Fire Colton / Redlands / San Bernardino City Fire
3775 <----- unknown but clear talk
3687 <----- Scanner just stops on this one (No talk )
2543 <----- Unknown
3535 <----- Fire / Unknown
1075 <----- Scanner just stops on this one (no talk )
3491 <----- Fire Fontana
3499 <----- Fire /'Med engine 23 not sure what city
1249 <----- Unknown but heard voice
3351 <----- Unknown but heard voice
3663 <----- Unknown
3527 <----- Fire unknown what city
kearthfan101
3489 2 DISP 1 (6 fire 2)
3491 2 CMD 1 (6 fire 1)
3493 2 TAC 1
3495 2 CMD 2
3497 2 TAC 2
3499 2 CMD 3 (6 fire 3)
3501 2 TAC 3
3503 2 CMD 4
3505 2 TAC 4
3507 2-CMD-5 (8 fire 1)
3509 2-TAC-5 (8 tac 1)
3521 3-DISP-2 (1 fire 2)
3523 3-CMD-6 (1 fire 1)
3527 3-CMD-7 (1 fire 3)
3529 3 TAC 7
3531 3 CMD 8
3533 3 TAC 8
3535 3 CMD 9 (4/5 fire 1)
3537 3 TAC 9
3539 3 CMD 10
3541 3 TAC 10
3549 Comm Center
Had posted this a while back. not all are confirmed, so it hasn’t been submitted until I can get out there and monitor more. It just seems like a likely pattern.
avdrummerboy
Mohave County, AZ
That's the list I was looking for, couldn't find it in the past threads. The ACO channel I know for certain as it is the exact same traffic as it was on the old analog system, the fire channels I'm sure we'll figure out in the next few weeks as fire switches over to the new system. Out here in Yucca Valley, the 4 system is showing out of range and the CC's aren't active on the scanner.
eggpro
Chino, CA
so I have the new p25 programed in the my BCD996X... I see when ontario PD dispatch is on, I hear them broken up.. is there a setting to fix so i don't hear them broken up? also does anyone have an updated list for P25 west valley? looking to hear chino PD
f40ph
Largest County, CA
Unfortunately, this is intentional. Unless they are "temporarily" in the clear which I'm certain won't last very long. They use P25 encryption and you won't be able to listen to any law enforcement in SBCo. Currently, you "can" hear FD channels, though.
My scanner does the same thing. Sometimes on PD channels, I can hear voice blips and chirps but usually nothing except for the scanner showing me the talkgroup is in use.
eggpro
Chino, CA
and what kind of scanner are you using? I remember when when I first started to program LAPD I had the same issues, I can't remember how I fixed it...
