yeah I was thinking as much. I was working to follow some poorly written directions about programming with an older version of programmer (v17) than the radio was last programmed with.
The radio itself is Flash: J2R13A02 SR:61CBFB0E0000 DSP: F4R06H01 type: 50 Watt
I used the wrote the radio flash to a file, and then used the recovery option. I did not have other data backed up but didn't realize I would need anything else due to carelessness. I'm still learning about the programming on these radios, as I have recently ended up with several of them to play with and re-use after reprogramming/cleaning.
During the recovery, I wrote back the file I had just saved, thinking this woudl somehow make my current programmer 17 work with the radio. Next it asked for tracking data, which I used the default for the m7100 vhf as the directions indicated. It then asked for a DSP file. I didn't have this. (bear in mind this radio hadn't been read by programmer before so no saved backup--my version was to old to read this radio) When I hit this road block I aborted. I found the radio was then interoperable, and read off and saved the DSP data from two other radios--one 50 watt model with another DSP version code (not the same code, but the same radio) and one from a 100 watt model with the same DSP version code. I redid the process of recovery, wrote back the file I had originally saved, then the default tracking data, and then pointd to the identical DSP version code that I'd pulled off the other radios saved file. Radio not supported/compatable or some other message. Started again and this time wrote the DSP file that was not the same, but was from another 50 watt radio. It took.
At this point I was sitting with a completed recovery process (Did not take the option to erase eprom) with the orignally saved flash file, the DSP file from another similar 50w radio with a differnt code, and the default tracking data. The serial number and flash code are still showing up correct to the radio. The ProGrammer can write data to it, and from the PC side everything looks good.
The radio itself only shows the perserr=0502
I have a new version of ProGrammer coming (the last/latest release) already for working on these radios anyway also as well, though I'm figuring that it will do no more good. Sadly, this radio was one of a set that I have also ordered additional feature options for.. This makes me particularly sick and particularly interested in finding a solution, but my knowledge of fixing my mess has hit some snags. I guess this is how you learn, thank goodness for forums and the internet..
