Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Harris / MA/COM / GE / Ericsson Forum
Harris / MA/COM / GE / Ericsson Forum - For general discussion of MA/COM EDACS and ProVoice systems, including equipment.
Old 06-08-2017, 9:11 PM
Default Macom P7100 Programming issue
Help please, How do I put a P7100ip into programming mode? It has been some time since I last did one I forgot. This is for a non EDACS radio.
dean m alexander
Old 06-08-2017, 9:12 PM
DisasterGuy's Avatar
Ptt and both side buttons while powering on
Sent from my SM-G900V using Tapatalk
Old 06-20-2017, 6:33 PM
I did that as well but I hit a road block it reads Key Zero
Old 06-20-2017, 6:41 PM
com501's Avatar
PTT, both side buttons + pwoer on is correct. Make SURE you are pressing all three buttons at the same time. It takes some practice (think Vulcan mind meld!).
Making your scanner useless, county by county.
Encryption, it pays my mortgage.
Old 06-20-2017, 6:46 PM
Default Programming
Still no go lol all three pushed and its on
Old 06-21-2017, 8:24 AM
The P7100 should put itself in to program mode if the cable is connected when you power it up.
My Scanners: BCD396T, BC246T, BCT15 (2), BCT15X, BC346XT, BCD996T, BCD996XT (2), HP-1, HP1E, PSR-800, BC125AT, BC536HP, BC436HP
Old 06-21-2017, 11:39 AM
kb4cvn's Avatar
Location: Nowhere near a paved road, away from the maddening world.
If you hold the two round side buttons, this is the KEY ZEROIZE function to dump the crypto keys in the radio.
If you are seeing this when trying to program the radio, you are not getting the PTT button depressed fully. This is either a pressure issue (not enough !) or a bad PTT button or button flex. The button flex was an problem on early model radios. (I personally have eight radios with this issue !) There is a repair kit or just swap the front cover.
In older flashcode, you had to hold all three buttons on power-up until you got a black fully-pixled screen. In later code when programming, you only needed to have a programming cable attached and hold the two round buttons on power-up until the display said PROGRAM.
NONE OF THE LATER PORTABLE RADIOS STARTING WITH THE J700p WILL GO INTO PROGRAM MODE just by powering-up with a program cable attached. That was a M-RK Series function and ended with that era.
Old 06-21-2017, 3:41 PM
All my P7100/5100 radios go into programming mode after you have the cable connected and the radio is turned on and then hit the program button icon in the software.No 3 key hold required to put the radio into programming mode unless updating the radio firmware or DSP, when prompted during the update process.
You have to have the more recent firmware and DSP in the radio.Older code requires the 3 key press to get into programming mode.
Old 06-29-2017, 2:23 PM
As far as I know, you don't need to put radio into "program" mode for programming channels/system. If you ready want to force radio to "program" mode. You can assign a "program" menu option on your "programmable menus". After you'v done that, simply navigate to that "program" on your radio menu and push M button.
Old 06-29-2017, 3:52 PM
You have to put a P7100/5100 radio in programming mode if the radio is using any DSP code older than J2R18.
I've actually tried adding the Program function into the radio menu of a P7100/5100 with DSP code J2R18 and it does absolutely nothing,but give you a "boop" tone.
Old 12-22-2017, 8:46 PM
Default P7100 programming help
I have 30 P7100ip radios that need to be programmed I had the city that owns them buy new RPM and RPM2
software and the license required. However when I connect the radio to the computer the program tells me " Radio code/personality is not compatible with this software. Please reprogram"
When I use the older RPM it tells me Error' Radio was programmed with a later version of radio programmer software.
My version of software is R10B07 and the newer version that the city bought is R14C05, is there some thing in between?
dean m alexander
Old 12-23-2017, 2:36 PM
com501's Avatar
You should be able to log onto the Harris website and upload the newest version for your subscription.
Old 12-23-2017, 2:48 PM
RPM2 is only for XG/XL radios. RPM 10B is very old. You need the current version of RPM1
Sent from my Pixel using Tapatalk
Old 12-23-2017, 3:22 PM
kb4cvn's Avatar
A lot of people (myself included) are holding at RPM R10b07, as you can program and monitor P-25 Phase-1 & 2 systems for educational purposes, but not require Harris' incarnation of a SYSTEM KEY, known as AAC.
R11a and later of RPM, and all revisions of RPM2 require a system key.
