Unity xg100p
dbestfirefighter
Dozer
Oklahoma
New to Harris RPM. Getting action failed when trying to activate mission plans. Found a step by step tutorial on here, went thru it and still getting the same error. Trying to program conv analog and conv p25. Any help would be appreciated.
DisasterGuy
Maryland Shore
Sounds like the personality file is invalid. What version of code is in the radio and what version of RPM are you using to create the personality?
Sent from my Pixel using Tapatalk
dbestfirefighter
Dozer
Oklahoma
Latest RPM. Just received it today from Harris. Software pic attached.
DisasterGuy
Maryland Shore
Can't promise it's the cause but the firmware in the radio is very old. Current release is XLP4. The oldest code I have running in any of our 100p radios is XGP5. May want to bring it up to at least XGP5 if not XLP code. Software services should be able to send to you if you have an account.
Thunderknight
Bletchley Park
I agree..it's a firmware version issue. Personalities created with newer RPMs won't load on very old firmware. I can't recall the exact version cutoffs, but that is old old firmware and very new RPM. We experienced it with a much closer difference than that.
