I recently picked up a CS7000 control station and it's working great thanks to a member here that helped me roll back the firmware.
1) Can the M7300 be set up as dual radio / single control head operation? I have an M7100 dual radio setup and if the M7300 can be dual-radio'd, I'd probably sell the M7100 stuff and stick with the M7300 as it can do Phase II.
2) As far as the CS7000 goes, which jumper needs to be moved to switch the programming port from "Serial A" to "Serial B?" Right now, it is using Serial A, which the USB port. It works, but I'd like to know for future reference.
Thank you!
Thank you!
