Go Back   The Forums > Commercial, Professional Radio and Personal Radio > Harris / MA/COM / GE / Ericsson Forum
Harris / MA/COM / GE / Ericsson Forum - For general discussion of MA/COM EDACS and ProVoice systems, including equipment.
Old 12-14-2017, 2:35 PM
kb4cvn's Avatar
Location: Nowhere near a paved road, away from the maddening world.
Exclamation PTT Button Issue
Do you have a P5100, P5200, P7100 or P7200 with a flaky or non-functional PTT switch?
Where if you removed the plastic PTT button and the black sealing goop under it, you can PTT the radio with a pointed object?
The earlier ‘fix’ was to replace the entire front cover. ($$$)
This was documented in TSM #TSM28-14B (November 15, 2007), and Harris later offered a PTT Repair Kit (PN# G4UK07720 ) to fix this issue. Total installation time is about 10 minute per radio.
New London Technology (434-525-0068) has a limited number of these repair kits available for $15.00/each. (I suspect this is a cheaper price than original retail.)
I purchased a few of the kits yesterday and they resolve the issue.
Old 12-17-2017, 7:34 PM
If I had a pristine example of the rubber button part that degrades, I COULD have it duplicated in long-lasting silicone rubber in quantities of thousands for pennies each.
I'm surprised nobody has done that yet.
No, I will not program your radio for you. No, I will not give you any software. Don't ask unless you want a rude answer.
Old 12-18-2017, 5:32 PM
That would be a great option!
Old 12-20-2017, 6:05 AM
I have done this to a number of radios, and while removing the PTT outer button can be tricky, the changes completely fixes the problem on radios with the problem.
All information here is Copyright 2012 by LLC and Lindsay C. Blanton III.Ad Management by RedTyger
Copyright 2015 by LLC Privacy Policy  |  Terms and Conditions
