XG-100P RPM question
TDR-94
Can an XG-100p programmed with RPM12 have a personality loaded into it with RPM10?
rescue161
KE4FHH
Hubert, NC
I can't speak for RPM12, but you may need to revert the firmware to something compatible with 10B. We went straight from 10B to 14 and it does cause issues for ours if we try to just program with 10B using newer firmware. So if we need to use 10B, we revert the firmware to R02A and then program away.
TDR-94
Was R05A compatible with RPM10B? I can't remember if it was or not.
Thanks for the info.
TDR-94
Does the Bluetooth connectivity initially require enabling from RPM via the USB programming cable?
rescue674aa
I’m an idiot
R05 is not compatible with RPM10..what are you trying to program?
TDR-94
The manual for the XG-100p (Rev R) seems to indicate that R3A is compatible with RPM10B.This is what the manual states.
In XGP R3A and later, the A/B/C switch can be programmed for multiple functions using RPM10B or later.
