Help with SVR-200 Repeater to M7100IP
nucleaireqc
Hello, I want to use one SVR-200 on 2 radio, one VHF and the other 800 MHZ
The MASTER radio is VHF (M7100IP)
The SLAVE radio is 800 MHz (M7100IP)
SVR TO MOBILE MODEL cable: Pyramid Orion interface cable Part # 7500-06-1014 for the SVR-200
I use the cable DUAL RADIO, number: CA101288V110 R1A
REMOTE MOUNT CABLE: CA101288V4 R3A
I followed Pyramid's instructions.
1. Under External Options, External Mute Program, active high output 1.
2. Program Aux Input 1 for PTT.
3. Program Aux Output 1: Custom, Active low, Output 2, Repeat checked. Custom pattern all checked.
4. Under Control Unit Keypad Options, one of the soft keys for AUX 1 to enable / disable the repeater
from the radio front panel.
When I am in analog of the mobile SVR and SVR Mobile everything goes well.
When I'm in Digital (MOBILE) the mobile receives my signal DIGITAL but the SVR does not retransmit this signal. When I use the portable linked to the SVR the mobile transmits without problem the DIGITAL.
Afterwards I wonder if the following configuration can work!
Used 2 radio on the same SVR and activated the SVR on the SLAVE radio is it possible?
tank you
