The RadioReference.com Forums
-   Harris / MA/COM / GE / Ericsson Forum (https://forums.radioreference.com/harris-ma-com-ge-ericsson-forum/)
-   -   Using GPS output of Macom 800 mhz antenna (https://forums.radioreference.com/harris-ma-com-ge-ericsson-forum/372650-using-gps-output-macom-800-mhz-antenna.html)
gspivey 06-25-2018 11:05 AM
I have a Macom 800 mhz antenna installed that has the integrated GPS antenna in the base which runs to an SMA male connector. Is it possible to use this GPS cable for my Uniden 536HP GPS input? If so, how would I connect it up? Thanks!
jonwienke 06-25-2018 11:28 AM
No. The scanner is looking for a NMEA format RS232 data stream, not a RF signal.
gspivey 06-25-2018 12:32 PM
Ok, thanks.
