Programming P25 Phase I
FDRadioguy777
I am trying to program a Harris radio to a P25 Phase I Trunking System. I am having to write a new personality since most of our P25 radios were switched to Motorola during an upgrade. Therefore I don’t have a Harris codeplug for our P25 System. My chief said he wants to use this Harris radio to just monitor from home so he said it doesn’t need transmit capabilities if possible. I am running into issues when programming it because when I write the personality the radio just shows CC Scan. Can someone please shed some light on programming a P25 Phase I System for a Harris radio? I am using RPM 13. If possible can someone please upload or PM me an example of what the RPM system info should look like. I kind of feel like the issue I am having is getting the IDEN set configured. Thanks in advance for your help!
DisasterGuy
Maryland Shore
There are several things that could be going on here as multiple items must be considered when crosswalking vendor equipment. My first question is if you have legitimate programming authority on the system and are working with a legit RID/LID specific to that radio? Next question is what model radio you are working with and if you have the Harris AAC authorization for the WACN/System ID in question? Final question is if you have the appropriate features enabled on the radio and if the system uses LLA?
Sent from my Pixel using Tapatalk
FDRadioguy777
Yes,the radio lid is legitimate. I am working with an XG-75P. Yes, the AAC seems to be working otherwise it wouldn’t let me program the system in. I just have not had to write a personality for Harris P25 Phase I before. I am planning to do receive only just to test until I can get someone to come out from the shop to verify it’s all good before letting it on the system.
overtheair
Durham,NC
Make sure you have the correct system information on the codeplug. I had the same issue and it turned out I had the wrong system nac.
