Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Harris / MA/COM / GE / Ericsson Forum
Harris / MA/COM / GE / Ericsson Forum - For general discussion of MA/COM EDACS and ProVoice systems, including equipment.
Old 09-16-2018, 3:00 PM
vinsky's Avatar
Default Orion
Hi,
is there a way to make an Orion radio to display the features in it?
Thanks!
Old 09-16-2018, 6:48 PM
BigLebowski's Avatar
If the menu option isn't turned on, you need to add it via Programmer.
Old 09-16-2018, 7:23 PM
vinsky's Avatar
Actually it is activated and the menu button works but it only shows backlight level and I can only go down with the button next to the scan one to something else and it shows 1. Am I missing something to be able to browse the menu?
Old 09-16-2018, 7:42 PM
Each menu item has to be added in the programming software to be accessed from the control head. If "Features" is not showing up in your menu items, it has to be added in Programmer.
Old 09-16-2018, 8:09 PM
vinsky's Avatar
I'm in the Options tab -> Programmable Menus. I can see that number 5 is assigned to Features.
Is it what your are referring to?
Old 09-16-2018, 8:26 PM
Yes.. make sure its enabled for both trunking and conventional depending on what you are using.
Old 09-16-2018, 8:30 PM
vinsky's Avatar
Yes they are both enabled. I did not change anything in that so they were activated since the beginning.
When you hit the Menu button on the control head, how do you browse for items?
EDIT: ok I got them. Left button.
Thanks a lot for your help!
