EDACS on Motorola radio
SlipNutz15
Wacker
Central PA
I've seen a forum post somewhere that says you CAN monitor an EDACS system with a Motorola radio but something about wide-WACN setting hex edit?
Can this actually be done for a non-affiliate scan an EDACS system with an APX?
riccom
ahhh no, reason being its like a English man talking to a puppy, the puppy is edcas and the man is mot 2 while in non trunking, yeah you can hear the voice, but can not follow, both are apco 16 compliant, but wont work.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Short answer is no unless you monitor the voice channels conventionally but you'll hear all the traffic and the beeps.
You're mixing up a few different technologies though.
A WACN is a P25 trunking term. EDACS is an ancient trunking technology that has nothing to do with P25 trunking.
SlipNutz15
Wacker
Central PA
Mike, yeah I couldn’t find the post about it. Maybe it was a Harris system that post was about. Does that make sense if it was a Harris System?
SlipNutz15
Wacker
Central PA
Ok. That’s my question then. How to monitor a Harris system on a Motorola radio. Not OpenSky.
SlipNutz15
Wacker
Central PA
There was a large post about it and having to force some system wide setting check box in the CPS for it to be able to monitor Harris. Not EDACS. I mistyped.
SlipNutz15
Wacker
Central PA
NAS still works on APX radios, look for that post.
Thank you but I was pretty certain the codeplug needed modified in an editor to allow it to monitor a Harris TRS because there was a check box that needed enabled and by default it wouldn't allow it to enabled.
BigLebowski
Piedmont NC
You are talking about the "Validate NAC to System ID" box. It works but your results may vary with NAS on Harris systems.
jhooten
Paige, Republic of Texas
Rarely seen in the wild, Motorola did do SP versions of the Astro Saber and trunking Maxtrac (I think, it has been awhile) for a government contract that would do EDACS.
