Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Harris / MA/COM / GE / Ericsson Forum
Harris / MA/COM / GE / Ericsson Forum - For general discussion of MA/COM EDACS and ProVoice systems, including equipment.
Old 11-03-2018, 1:03 AM
SlipNutz15's Avatar
Default EDACS on Motorola radio
I've seen a forum post somewhere that says you CAN monitor an EDACS system with a Motorola radio but something about wide-WACN setting hex edit?
Can this actually be done for a non-affiliate scan an EDACS system with an APX?
G. Stottle KB3THR
http://www.centralpascanner.com
Old 11-03-2018, 2:39 AM
riccom's Avatar
ahhh no, reason being its like a English man talking to a puppy, the puppy is edcas and the man is mot 2 while in non trunking, yeah you can hear the voice, but can not follow, both are apco 16 compliant, but wont work.
Rd-5r pro-2062 bf-8hp beojie 218 bc335c qyt 8900D and a partridge in a pear tree!
Old 11-03-2018, 6:57 AM
MikeOxlong's Avatar
Forums Manager/Global DB Admin/Commie
Short answer is no unless you monitor the voice channels conventionally but you'll hear all the traffic and the beeps.
You're mixing up a few different technologies though.
A WACN is a P25 trunking term. EDACS is an ancient trunking technology that has nothing to do with P25 trunking.
Mike.
Old 11-03-2018, 1:04 PM
SlipNutz15's Avatar
Mike, yeah I couldn’t find the post about it. Maybe it was a Harris system that post was about. Does that make sense if it was a Harris System?
G. Stottle KB3THR
Old 11-03-2018, 1:09 PM
riccom's Avatar
Now Harris is full p-25(thank God opensky was a joke) and there edacs was a very very good system, it took a lot of money to keep up, but the return was sound.
Sent from my 5049Z using Tapatalk
Old 11-03-2018, 1:10 PM
SlipNutz15's Avatar
Ok. That’s my question then. How to monitor a Harris system on a Motorola radio. Not OpenSky.
G. Stottle KB3THR
Old 11-03-2018, 1:12 PM
riccom's Avatar
Ok buy a scanner on eBay with triple trunking they are less then 100 bucks
Old 11-03-2018, 1:13 PM
SlipNutz15's Avatar
Nope. Thanks.
G. Stottle KB3THR
Old 11-03-2018, 1:14 PM
riccom's Avatar
You can not, as posted before by myself and others.
Old 11-03-2018, 1:17 PM
SlipNutz15's Avatar
There was a large post about it and having to force some system wide setting check box in the CPS for it to be able to monitor Harris. Not EDACS. I mistyped.
G. Stottle KB3THR
Old 11-03-2018, 1:18 PM
riccom's Avatar
What model of Motorola is the radio
Old 11-03-2018, 1:19 PM
SlipNutz15's Avatar
APX7000 and or APX7500
G. Stottle KB3THR
Old 11-03-2018, 1:20 PM
riccom's Avatar
Set it on conventional, and find the dac code, and make sure not to affiliate with the system or it will get bricked
Old 11-05-2018, 2:10 PM
Location: New York North Carolina and all points in between
NAS still works on APX radios, look for that post.
Old 11-05-2018, 2:46 PM
62Truck's Avatar
Scanner or Unication G4 or G5.
Lions, Tigers, Bears....
Old 11-05-2018, 7:12 PM
SlipNutz15's Avatar
Thank you but I was pretty certain the codeplug needed modified in an editor to allow it to monitor a Harris TRS because there was a check box that needed enabled and by default it wouldn't allow it to enabled.
G. Stottle KB3THR
Old 11-05-2018, 8:18 PM
rescue161's Avatar
KE4FHH
The Harris system that I manage has Motorola radios on it and they will work with NAS.
Hams Against Magnetic Mounts
Old 11-05-2018, 8:21 PM
SlipNutz15's Avatar
I'm going to message you if you don't mind.
G. Stottle KB3THR
Old 11-07-2018, 10:36 PM
BigLebowski's Avatar
You are talking about the "Validate NAC to System ID" box. It works but your results may vary with NAS on Harris systems.
Old 11-08-2018, 7:21 AM
jhooten's Avatar
Rarely seen in the wild, Motorola did do SP versions of the Astro Saber and trunking Maxtrac (I think, it has been awhile) for a government contract that would do EDACS.
Jerry
I read it on the internet, so it must be true.
Tags
apx, harris, motorola, non-affiliate
