Go Back   The RadioReference.com Forums > HF / MW / LW Monitoring > HF/MW/LW Equipment
HF/MW/LW Equipment - For general and technical discussion of all receivers which cover the HF bands. For HF tranceiver discussion please use the Amateur Radio Equipment forum above.
Old 07-09-2017, 3:40 AM
cherubim's Avatar
Default Digitech AR-1780
Jaycar Australia has just launched a new portable SW receiver with SSB:
https://www.jaycar.com.au/pocket-wor...h-ssb/p/AR1780
Looks interesting. I wonder how it performs on SSB as the AR-1945 was hopeless in this respect.
Old 07-10-2017, 12:58 AM
Probably the same guts as your average Tecsun? I.e. a SiLabs DSP chip with all the bandwidths, etc.
Old 07-10-2017, 2:45 AM
cherubim's Avatar
This radio definitely has an SiLabs DSP and for that reason it will probably suffer from SSB distortion like the PL-880 does.
I'm hoping to test one out soon to see if it's usable for SSB reception.
Old 07-14-2017, 8:18 AM
Default Tune muting
Another interesting point is if this new radio does also have the infamous tune muting of all DSP radios.
Old 01-22-2018, 1:35 PM
WRONG - The Digitech AR-1780 does NOT use a SiLabs DSP chip. The Chinese most likely have copied the architecture of the Silicon Lab's DSP chips and have improved it.
The new Digitech AR-1780 uses the new Boardcomm BK1088 DSP chip that has full shortwave coverage up to 30 MHz and also has SSB that sounds very good. The Boardcomm Company is located in Shanghai, China ).
Here's the proof - Go to https://www.yidianzixun.com/article/0IAtG2HF/amp Then copy and paste the URL into Google translate so you can read the article in English.
Old 01-24-2018, 7:48 PM
FWIW, not all DSP radios have muting. I have two SiLabs DSP equipped radios (a PR-D5 and Grundig G2) that do NOT mute.
