Go Back   The RadioReference.com Forums > HF / MW / LW Monitoring > HF/MW/LW Equipment
HF/MW/LW Equipment - For general and technical discussion of all receivers which cover the HF bands. For HF tranceiver discussion please use the Amateur Radio Equipment forum above.
Old 01-05-2018, 8:08 AM
Default Tecsun PL-660
This is very strange! This radio worked great for 3 months. Yesterday I fired it up, no signals strength on any bands including local FM stations. I did the recommended reset, removed all sources of power, still nothing. I also tried an external antenna.
I changed the FM band width to the available 76 MHz from 88MHz. around 77MHz I am receiving a couple a local FM Stations which are in the 96 MHz range. Still nothing on an other bands. Anyone had this issue or suggestions on how to remedy it? Thanks in advance.
Old 01-05-2018, 8:39 AM
HudsonScannerGuy's Avatar
Maybe something shook loose on the inside.
YAESU FT-70DR BCD436HP YAESU VX6R Panasonic RF-1150
Uniden Force UHF HT PRO-65
/AG HAM
IRLP node 4133 if you want to QSO with me!
