Let's start to answer this question with a little theory (just a little, promise). Insofar as receiving goes, a transmatch (antenna tuner is a very inaccurate term) can create a resonant path between the antenna, feedline and the receiver. You'll notice I included the feedline; in some cases, the feedline is actually part of the antenna itself (a common antenna where this is true is the classic Inverted L). Put simply, it can allow as much of the signal to get to the receiver as is possible (there are some losses involved but let's not get too deep into that right now)
There is some controversy as to using a transmatch with a receiver. Most say that modern receivers don't need any matching; if the wire is long enough, you're good to go without any tuning. However, there are cases where a transmatch might be helpful; for example, if the antenna is too short to be naturally resonant on a particular band, a transmatch might bring the signal up. Using a transmatch on something that is not normally an antenna - say, aluminum gutters as an example - would also be a good idea.
Now a little more theory. The term 'long wire' is one of the most misused terms that describes an antenna. A long wire can be just that - a wire that is very long. There is a very specialized kind of antenna that is called a longwire (note there is no space between the 2 words). Basically this is an antenna that is usually fairly close to the ground and is 1 wavelength long (or more) at a given frequency. The classic Beveridge and the V beam are types of longwires. You wouldn't use a transmatch with such antennas.
Generally speaking a length of 80-100 foot is sufficient for most applications. In this case, a transmatch isn't going to get you anything. However if you're stuck with, say 45 or 50 foot, yes a transmatch might help if you tune below 6 Mhz or so. Certainly a transmatch can help if you are trying to tune with gutters, or some other metallic structure that is not necessarily useful as an antenna in other circumstances
Getting a transmatch that can handle 1kw is a waste of money, unless of course you are using it for ham use running that kind of power. Even QRP (low power) transmatches would work just fine with receivers like the R75.
