Why "nit-pick" ? Because it is basically perfect.
The radio has been reviewed many times elsewhere, so I won't repeat all that, but provide some observations not seen..
AIRBAND DONE RIGHT for this form-factor!
Someone in engineering must have been an airband enthusiast / pilot who appreciates good audio. Which means that when wearing headphones, your ears aren't blasted with a bad agc, and even wearing more hi-fi headsets like Sennheiser MX-365 buds sounds great.
My pilot-buddy actually sounds like himself when I hear him landing at my local GA airport. The last time I *ever* heard good airband audio was from the Grundig Satellit 800. (NOT the lesser 750!)
Yes, the first syllable is missing, but if that means protecting you from a bad fast-attack that is distorted, well so be it. Squelch is reasonable on the ears too, especially when wearing headphones, which means extended listening won't tire you out with listener fatigue. It is far more pleasant to listen to than my Uniden scanner, I'll tell you that - despite the scanner being more designed for rf performance.
Being able to choose your own bandwidth is appreciated as I narrow it a bit when wearing phones, and widen it when listening to the speaker just to get a little more intelligibility out of it. Having THREE selections, rather than just a wide/narrow that actually works, is really appreciated.
Notable is the 21" whip, which just happens to be the quarter-wavelength for airband as well - albeit the radio circuit board is not much of a groundplane. AND, the very last section of the whip isn't some micro-bendy extension. Nice touch.
My weak local airband ATIS signal is easily received, on par with my scanners that have high-q airband-specific ducks like the Icom FA-B02AR attached. [provides a measure of bandpass filtering if you will] Impresssed - I didn't expect that kind of performance.
I haven't experienced any overload, but testing with the whip totally collapsed, and sitting at the visitor center at my local GA airport posed no issues, nor when flights arrive right near my closest waypoint.
FM - the 21" whip isn't a problem on FM since the radio is very sensitive. I don't need a full-length whip to hear my local Low-Power community station with its 10 mile coverage area. (KHUG rocking the blues at night, normal programming daytime). It basically picks it up as easily as my CC 2E desktop does.
AM - superb. Weather - great performance here as well.
High-resolution S-meter - didn't expect that either. Us radio nerds appreciate the higher resolution.
There's really no reason for me to go on - anything else is just a nit pick. All other radios in this class are a total JOKE when it comes to airband. Not so the Skywave. Rather than going under the mallet and anvil, the Skywave stays on the desk.
