cjrjr507
Hi all stereo listeners
I had my 8 inch sub by the right rear wall about 8 feet from my listening area for a long time but was not impressed with the bass response. It was ok but I thought it could be better, so I moved it tonight in back of the stereo system behind the lcd tv and placed it on the floor parallel to the stereo with the front facing to the right wall. Well I was shocked at the difference of the bass response. I can here all the freq's now, Boom! I can imagine what an 12 or 15 inch sub would do. Yikes! Oh and I set the sub on normal instead of reverse. I tried it on reverse on the sound went out of phase and sucked. Now if I only had 2 sub's, heh heh.
Try it out, the bass is awesome. Oh and I have the sub set for 50 hz cutoff and main speakers at 50 hz.
See you later and crank the volume, ha.
P.S. I need better main speakers, when I can afford them. Cerwin Vega XLS 215's, heh heh
