ottosykora
I need to have a channel where a regular communication in talk around simplex takes place. At the same time I need to monitor repeater output on other channel.
I have set the TA channel as digital priority channel.
So far the priority channel seems to behave as it should, transmissions on it are heard with minimum interruption from the repeater channel.
But when I try to call via the repeater channel, the call is not registered unless I make 3 transmissions on the repeater.
This includes also the ALLCALL!
If I transmit on the repeater output in talk around mode, the call is registered (slightly delayed by prio scan) but it is registered fine.
ALLCALL on talk around (repeater output) captured the receiver almost immediately.
Any idea why the repeater has such big problem to reach the radios?
