ICOM F50v Programing
starfixer
have slight problem all appearts to work on radio it transmits appears to recieve by light indicator, but you cannot hear the recieveing transmission. What would I be missing, any help appreciated. thanks. Also note the inhibit is not turned on on the channels programmed in the radio. this problem is on all channels. also looking for guidiance on how to setup the paging part have put the codes in couldn't find area for the cap code. Help please.
rescuecomm
Travelers Rest, SC
The light on top can come on if the squelch setting is not high enough. The radio is receiving noise, but no PL/DPL is detected so there is no audio. There is a general settings page where this squelch number is set.
Bob
starfixer
thanks
will try what you both have suggessted, but I did check the squelch and it is not the issue, but I do have both channells set to recieve our paging tones also, should that be moved to a seperate channel of their own? They are suppossed to be working as our pagers also but are not.
starfixer
checked my settings attached is the icf if you can look at it and tell me what else might be causing it. would be very appreciated. changed to txt extensesion to post
  • Copy of test1.txt
rescuecomm
Travelers Rest, SC
If you have two-tone selected on the same channels, you won't hear anything until the tones are set off. The page tones for receive should be on their own channels. It would be used for when you don't want to hear normal comms.
Bob
phbrush
Maine
F50V Portable paging problems
Take a good look at the tone programming. There is a place to enter a "no-tone" delay between first and second tones. I am having problems getting the F50V to decode reliably if the delay between tones (Motorola uses 250 msec) is greater than 100 msec or so. I would like to hear from anyone who has had similar problems getting the F50V to decode in Fire Service.
24-medic7
Denison Iowa
IC-F50V Paging Problems for extended time between A and B tone
In your programing software for your IC-F50V's you will look under the (2 tone) opsitons. Select the tab that says (RX code settings), this is where you are going to set the gap times for your tones. It may take some programing and furnessing to get them to be exact. Where it says (No TONE, {SEC}) This is where you are going to set that gap time between your A and B tones. So in there since you are running 250mes.. Then you are going to want to enter (a time between 2.40-2.50) Since you are running the 250mes i would go ahead and set to 2.50 and see where that gets you.
