Icom f50v clonning problem
NSFD400
North Carolina
I've got several F50V transceivers, the CS-F50MDC programming Software, and the Icom OPC-966U clonning cables. Everything is loaded on my computer but when I attempt to read the settings in the transceiver I get a "no answer from the transceiver" message. Can anyone make a suggestion that might solve my problem?
tc792
West Central Texas
Is the problem with just the one radio or all of them?
If it is only the one, could be an internal problem with the Accessory connector. Repair required.
stevelton
Check your com port settings in the software.
I know with my cables, I can plug them into the same usb port every time, but the computer assigns that usb a different com port number.
Go into your computers device manager after you plug in your programming cable to see what com port it is set to, then set that number in your software
