methusaleh
I recently got a great deal on two F4GS HTs but I am having trouble with them. At first it was one radio, now it is both. Any and all assistance is greatly appreciated!
Both radios were received and originally tested yesterday, but briefly.
Radio #1 - The radio powers up fine. Sometimes after powering up, the display starts flashing (backlight is on, LCD figures flash). Sometimes it does not. Radio does not RX and does not seem to TX, however sometimes when I press the PTT, the little "lightning bolt" icon appears on the screen, as if I am TXing, however nearby receivers do not receive anything, not even a dead carrier. Tested with 3 different batteries, same results. It took four tries before my computer would read it, I kept getting error messages. I was finally able to read it, and today I added a couple channels and programmed it with those. Radio still does not TX; LCD characters on the display blink sometimes when PTT is pressed, "lightning bolt" symbol sometimes appears when PTT is pressed.
Radio #2 - Worked fine yesterday on intial testing. Powered up, RX and TX fine, software was able to read on the first try. Today I went to read the radio again, and after about 50 attempts I can not. Nor can I write to it. Using the same cable and software, I am able to read and program an F3GS that I have, so I am guessing the problem is the radio and not my computer or setup. Radio still TXs and RXs fine, I just can not get my software to acknowledge it.
