Programming IC-2200h
tallen74
Beebe, AR
Wanted to confirm what all I need to program 2200h with laptop. USB PC to 2200h cable and the windows cloning software. Anything else?
Thanks in advance
SCPD
QRT
Virginia
You need the OPC-478UC which has the driver CD for Windows XP. You also need the software CS2200H which is the software package.
Apparently the driver CD does not have Vista drivers so you cannot use Vista.
WayneH
Forums Veteran
Super Moderator
Your master site
The ICOM Receivers forum is for receivers only. Please use the Amateur Equipment forum in the future. Thread moved.
