omi713nm
A quick question on the programming software. With narrowband just around the corner, was just wondering if I am correct on this:
You have a channel that you talk to your dispatch with on a regular basis and it is set to Wide at this time. You decide to change Wide to Narrow on the programming. OK, here is the question:
when you transmit to dispatch, does the radio convert the frequencies to Narrowband or do you need to program the narrowband frequencies in and place the programming to N when you program the radio?
