Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > ICOM Land Mobile Radio
ICOM Land Mobile Radio - Discussion forum for ICOM land mobile radio equipment such as the IC-F series radios. Please do not post amateur radio topics here.
  #21 (permalink)
Old 10-03-2014, 4:10 PM
I got zero PM's jeatock
  #22 (permalink)
Old 10-04-2014, 11:22 AM
Jeatock, the PM system appears to be broken. You can email me directly at " rick at lioby dot com "
  #23 (permalink)
Old 10-12-2014, 9:38 AM
I noticed recently that the F3021 has been discontinued completely and replaced with the F3031. I would suspect that the F3031 will not do WFM at all.
  #24 (permalink)
Old 03-18-2015, 3:29 PM
MTS2000des's Avatar
So not to bring back too old a thread, but I recently acquired an F3261DS, and the current firmware is R4.9, DREV 3.2, but displays "F NARROW ON"...I have a 3161DS that has the same firmware version and DREV but no "F NARROW ON"...would love to be able to program wideband for ham use.
Anyone know the workaround? Is it going to take sending the radio to Kirkland to get some magic wand waived?
I have not tried to read the radio yet, as my OPC-1862 is on the way. Just want to know what kind of battle I am up against. I've read through this thread and there are two conflicting answer.
One poster says Icom "unlocked" his radio, the other poster copied and pasted a response from Icom saying essentially you are SOL.
So which is it?
NO I will not help program your trunking radio. All opinions are exclusively those of the author and in no way reflect the position of his employer, contractors or other parties.
  #25 (permalink)
Old 03-18-2015, 7:33 PM
The new 3261 series is not wide band capable. Also, the 3161 and 3261 use totally different firmware/software packages You may brick a radio is you try a firmware mismatch. Here's the emission designators from the specification sheet for the 3162:
Type of emission 11K0F3E / 4K00F1E / F1D
This comes out to 12.5, 6.25, and digital only. No wide band designator indicated.
Yes, the 3161 is wide band capable, but not the 32 series.
Compare the spec sheets and you will see.
Sorry to share bad news.
  #26 (permalink)
Old 03-18-2015, 7:35 PM
I meant to say "spec sheet from the 3261"
  #27 (permalink)
Old 03-18-2015, 7:51 PM
MTS2000des's Avatar
News to me. The same REV4.9 and DREV 3.2 is what is in my 4161DS, and according to Icom the same cloning software programs the 3261 series (CS-3160/5060) so how can the firmware and software be different if they use the SAME CS and have the same version numbers?
Not trying to be argumentative, just trying to understand.
  #28 (permalink)
Old 03-19-2015, 6:06 PM
Yes I probably jumped the gun on the firmware/software statement. I was thinking of when the F3061 was upgraded to the F3161 several years ago. The firmware/softare combinations for those models were incompatible. I just ASSumed it was the same for the new F3261. I stand corrected.
As for wide band capability, I "believe" the F3261 is designed for wide band only based on the emission designators in the specification sheet.
F3161 SERIES:
Frequency range
IC-F3161T/S
IC-F4161T/S
136175 MHz
400470 MHz
450512 MHz
Number of channels 512 channels/128 zones
Channel spacing 12.5 kHz/25 kHz, 15 kHz/30 kHz, 6.25 kHz (option)
PLL channel step 2.5 kHz, 3.125 kHz
Antenna impedance 50Ω
Usable temperature range 30C to +60C; 22F to +140F
Power supply requirement 7.2V DC
Current drain (at 7.2V DC)
Transmit
Receive
VHF/UHF 1.5A/1.8A (at 5W/5W)
stand-by 100mA
150mA
rated output 600mA
Dimensions (with BP-232)
(projections are not included) 53 (W) 136 (H) 38.9 (D) mm;
23⁄32 (W) 511⁄32 (H)117⁄32 (D) in
Weight (approx.) 338g; 11.9oz (with BP-232N)
Transmitter
Output power 5W (VHF), 5W (UHF)
Max. frequency deviation 5 kHz (Wide) 2.5 kHz (Narrow)
F3261 SERIES:
Frequency Coverage IC-F3261DT/DS: 136174MHz
IC-F4261DT/DS: 350-400MHz, 400-470MHz, 450-512MHz
Number of channels 512 channels / 128 zones
Channel spacing 12.5 / 6.25kHz
Power supply requirement 7.5VDC nominal
Current drain (approx.)
Tx High
Rx Max. audio/Standby IC-F3261DT / DS
1.5A (at 5W)
600mA / 150mA IC-F4261DT / DS
1.8A (at 5W)
600mA / 140mA
Operating temperature range 30C to +60C
22F to +140F
Dimensions (with BP-232N)
(projections are not included) 54 (W) 142.7 (H) 39.5 (D) mm; 2.13x5.62x1.56in.
(With BP-232WP)
Weight (approx.) 370g; 13.1oz (with BP-232WP)
Transmitter
Output power 5W, 2W, 1W, (Hi, L2, L1)
Max. frequency deviation 2.5 kHz
As you can see, there's no wide band specifications indicated for the F3261.
  #29 (permalink)
Old 03-19-2015, 7:29 PM
I'm making mistakes left and right............
The above should read:
As for wide band capability, I "believe" the F3261 is designed for NARROW BAND only based on the emission designators in the specification sheet.
  #30 (permalink)
Old 03-19-2015, 7:48 PM
rapidcharger's Avatar
This is also incorrect.
It'll do wideband just fine provided the firmware is 4.9 or older.
  #31 (permalink)
Old 03-29-2015, 4:29 PM
hotwatt's Avatar
I have no problem making wide band on my f4001 but i use narrow since thats the norm i donno what the diff is though
  #32 (permalink)
Old 05-05-2015, 7:58 PM
I realise this is an old thread but I was wondering if any info regarding an IC-F6021 being able to be changed to wide band.
I recently purchased one from the US for Australia (we still use wide for some service's) the wide setting is available in the CS-5021 software but always defaults to narrow after programming, any information regarding a possible solution greatly appreciated.
  #33 (permalink)
Old 05-05-2015, 10:02 PM
The word I got right from ICOM is that the newer radios have firmware in them that only allows NFM.
I am not sure how to tell an old firmware version from a new firmware version without trying to program it.
The wholesaler that I buy from told me that he was not aware of anyway to do it on the newer ones. In fact, he asked me to let him know if I found a way.
The last few radios that I bought I bought used on ebay specifically because I did not want to buy a new one and be stuck with NFM only. I have both a commercial license for my farm and also a ham license, so I wanted to be able to do both.
If you find a solution that actually works, please do pass it around.
Rick
Rick
WA1NIC, WQAV-895, WPIH-815, PG0111912
  #34 (permalink)
Old 02-02-2016, 10:11 PM
Rapidcharger, I have an F3261DT with REV 4.6.2 RR / DREV 3.2 firmware and from what I've read and no matter what I've tried, I'm stuck with narrowband only. If you know of a way to make my radio TX/RX wideband, I'd sure like to know what that is. I'd love to be able to use this radio for 2m communications also.
BCD536HP, BCD436HP, BCD996P2, BCD996XT, BCD396XT, BC780XLT, HomePatrol HP-2, HomePatrol HP-1 & HP-1 Extreme, Motorola XTL5000, XTS5000, XTS3000, Kenwood NX-800, NX-700H, TK-8180, TK-7180, Icom R7000
  #35 (permalink)
Old 01-26-2017, 10:26 PM
IC-F4261DT converted for WFM for use in the amateur band:https://drive.google.com/open?id=0B5...0dhMFFGSUgyc3c
  #36 (permalink)
Old 01-28-2017, 3:04 AM
That's interesting. Is that a function of the newer firmware? I'm running the RR firmware (REV 4.6.2 RR) on my F3261DT and holding the PTT and F1 does nothing when powering the radio up.
As far as I've seen, these radios only transmit with either a 12.5 kHz or 6.25 kHz channel spacing. When you set the radio to wide, does it allow transmitting on a 25 kHz channel spacing or does it just force the radio to 12.5 kHz only?
  #37 (permalink)
Old 01-29-2017, 12:12 AM
I use the radio for ham radio and being forced to narrow FM was not an option for me. The radio was locked in narrow FM (as known to many people here) and there was no way to make it WFM. You'd program the radio Forced Narrow OFF; however, when reading it back, the .icf file would be in Forced Narrow ON.......sent it to dealer to modify it with "special SW". These radios are sold world wide where there is no 12.5khz requirement. The SM has a procedure to adjust WFM dev... go figure.
I am a happy camper with this radio now!
Yes, it allows the radio to transmit in 25khz.No, its not a function of FW 5.3
Under common>common>others>forced Narrow change = enable in order for you to be able to change the forced enable on and off when pressing p1 and ptt while powering the radio on.
  #38 (permalink)
Old 01-31-2017, 3:22 PM
Okay, so just to clarify, you had to send the radio to a dealer for modification so it transmits with 25 kHz channel spacing.
Thanks.
  #39 (permalink)
Old 02-02-2017, 8:09 PM
Thanks.
It's special firmware that not all dealers will hand out like candy. The dealers usually have to go thru the act of congress to get it and each model is different. Each model requires approval from ICOM.
  #40 (permalink)
Old 02-02-2017, 8:20 PM
That's what I was afraid of. Well, if anyone knows of a dealer in Southern California (Los Angeles or Orange County area) that can flash the firmware to allow wide channel spacing for ham use, let me know. If not, I guess it'll eventually end up on eBay.
Thanks everyone!
