Icom IC-F70T Scan
Tunkhannock, PA
Hello,
I just got an Icom IC-F70T not to long ago, and I'm still confused with all of the scanning options. I need it to be Priority scan A-B, but I can't figure it out. Also, is there a way you can have a different Priority A and B for different scan lists or no?
cabletech
Puget Sound
Go into you program, select the channel bank you want then select channel you want for the 'A' priority, press enter, select A, then go to the channel you want for the B priority, press enter, select B.
Now go to the right and select scan list 1.
You can only have the two priority channels, but the way this works, you have channel 1 as A and 5 as B, you are on 3 with no traffic, traffic starts on 5 the receiver goes to 5, break in the traffic and the radio hears channel one and changes, in the mean time all traffic on 3 is ignored.
You can NOT have different banks in the same scan list as they Will NOT CROSS BANK SCAN.
Hope this helps
Tunkhannock, PA
It does help a little bit, but what Scan setting should I choose? Also does anyone know how to change the light stay on timer? If there even is one.
