ICOM IC-F4S-4 (segment of UHF band)
Gregg251
Greensboro, NC
Is there a way of telling exactly which segment of the UHF band this radio covers? When programming, I get a CL good indication from the radio, but some frequencies flash, and others TX but not RX. Serial no. is 107163 if that helps.
Thanks, Gregg, N2UUP
cabletech
Puget Sound
Read the radio, then select clone>information, this should help you figure out the frequency split.
If that does not work, the next easiest way is to contact Icom tech support and they can help locate the split.
What is the lowest and highest TX/RX frequency that works? The radio comes in two splits for UHF,
split 1 is 400-430 and split 2 is 440-470.
The radio is not designed to operate more then a few kz out of the split.
