BIIS function for F1821D-11 (Vhf)
cortchubby
Chicago Illinois
I have a question re BIIS for the Icom F 1821D and the F2821D radios.
Is this an add on board or is this something that can be activated via software/firmware?
If add on board can anyone please provide the Item number for this as I will need to purchase
4 of them for our fleet.
Thanks all in advance.
rapidcharger
The land of broken calculators.
It should come standard but I've noticed for BIIS, you have to select a particular model from the drop down menu and if you select that, you lose the option to program MDC. So its kinda one or the other if that matters.
cortchubby
Chicago Illinois
Re:BIIS
Right the drop down menu has the provision for BIIS but when I load a test program into the radio (F2821D-22) the screen says "radio does not have BIIS" so Im wondering if Im doing something wrong in the programming or this function simply isnt in this radio and needs to be added on like an optional board.
The need for this is to send messages to the units in the field on a unit specific basis. Ill dig a little further but if there is any light that can be shed it would be appreciated!
